THUNDERZ Posted January 27, 2004 Share Posted January 27, 2004 where is the large ventilation tube that comes out of the drivers side of the engine block supposed to connect when you are running triple carbs? I have a vent on the valve cover outlet. Please help if you can. Thank you. Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted February 2, 2004 Share Posted February 2, 2004 You're talking about the PCV and hose....this usually vents back into the intake log/manifold. I have sen K&N breathers/filters in place of these rebreathers though. I'm not 100% if you're supposed to remove the valve and hose, and just put the filter on, or use the valve along with the breather. I have seen these breathers on the 2.6 (that I pulled) in place of the rebreather for the valve cover and the PCV hose though, so I know it can be done. http://www.zcarparts.com has these breathers and VB may also. I have seen them on ebay too. Chase Quote Link to comment Share on other sites More sharing options...
