TACHOMETER!!!!!
THUNDERZ
I have an 80 L28 in my 260. I have not been able to hook up the tach as of yet ...because I cant figure it out. The distibutor is from the 80 zx. So I wanted to know if anyone else has run into this, and what direction is best to head in. Thanks :lol:
Oh yeah...Does anyone know how to test the tach?
The only clue I can offer is that my local library has quite a few wiring diagrams. I go in and look at/copy them for my vehicles, and go from there.
The 260 should have had a tach wire going into the engine compartment. If you can get a diagram, it should show the color of the wire, allowing you to find the loose end and put it where the diagram specifies.
Did the 280 have electronic ignition? If so, then you may have to study two diagrams to see if the tachs hook to the same place.
Good luck!
