Guest szlash280z Posted January 28, 2004 Share Posted January 28, 2004 I think I have a clogged fuel filter! That's probably why my car started detonating at only 10PSI! My pressure is sitting at 20PSI even with the vacuum line removed. My fuel pump is a new walbro type. Fuel filter is likely the only thing that can be causing the pressure drop! (my gauge is mounted above/after the fuel filter!) cool! Now I get to change it tomorrow! Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted January 28, 2004 Share Posted January 28, 2004 could be the fuel filter, but may be the fuel pressure regulator has gone south... Quote Link to comment Share on other sites More sharing options...
fl327 Posted January 28, 2004 Share Posted January 28, 2004 Once clogged a fuel filter so bad that the car would barely move. When I changed the filter, fuel pressure went from 40 to 60psi!! Its definitely possible it was the filter causing early detonation. I change the filter every couple months now, and try to keep some gas in the car at all times, fill up early and what not. Quote Link to comment Share on other sites More sharing options...
