Horsepower off of mods
Guest dawg95_2000
Guest dawg95_2000
How much horsepower and/or torque would I get if i perform the following things to L28:
Flattops w/ N47 head and felpro gasket- 10.1 compression?
2.5 exhaust, no cat, dynomax super turbo
Half-arse match port job and maybe port the intake and exhaust manifold as best I can.
If anyone can give me some estimates- optimistic or not, it would be appreciated.
Guest bastaad525
I had nearly the same motor, built up in stages (eventually it ended up being a 2.9L, with a mild cam, rebuilt SU's, headers... you name it) when I was at about the stage you're talking about I was putting down about 150hp at the wheels.
well, stockers put down about 125rwhp in gooood shape, most are putting down in the high 1 teens. as in about 118rwhp. so, if bastaad525 was laying down 150rwhp, thats about a 30rwhp jump in stock, which would be damn good! that'd be about what, 40 flywheel hp? I plan on doing prettymuch the same thing. except I am using a maxima N47 which should be good for about 10.5:1 and has nicer chambers. that and I am also installing a 260Z "C" stamp cam. 256 degrees duration on both sides. which would be a nice 16 degree jump over a stock late model P79 cam. I'll be happy with about 160rwhp.
McAdam
I think a good starting point is double that. :lol:
Does the 260 cam have oil holes in it? I am thinking not but cannot really remember, so you may need to come up with the cam towers off an early model head, and the spray bar, or you won't have 16 degrees more duration for long.
lol! yes, the cam woulndt have that much duration for long! But, yes the 260Z had an oil spray bar. I snagged that along with the cam towers off of the E88 head. I also pulled all rocker arms and kept them in order, along with lash pads. I got the complete set-up for $25, lol!! its going in the car in about a week or so.
McAdam
Guest bastaad525
found my old dyno sheet, actually my rwhp at the time, which was a 10.3:1 compression motor, flat top pistons with an N42 head, stock cam, stock EFI with an adjustable fuel pressure regulator to increase fuel for the higher compression, 3-2-1 headers into free flow cat and muffler, 60mm throttle body, made 141rwhp at 5200rpm, and 160 ft lbs at 4400rpm.
how many miles were on the bottom end? i think the cam was the limiting factor there. Also, my head has minor valve bowl work where I cleaned up a few of the shapr ridges in there. It should be fun. hopefully I'll have it done in time for the local 240sx clubs dyno day.
McAdam
Guest bastaad525
The entire motor was rebuilt. I also had the bowls smoothed out a little, and some minor (very minor) smoothing of the ports as well. This was also with .060" over sized pistons, which technically made the motor a 2.9L.
The only things I changed to bring it up from 141 to 160hp was switching over to SU carbs and putting in the mild cam (480 lift 270 duration cam), and of course not running a catalyst anymore, these changes were made when I pulled that motor from my '81 ZX and put it into a '72 240.
Mine made that much HP before the boost hit. HAHA
Sorry I could not help it. :lol:
The entire motor was rebuilt. I also had the bowls smoothed out a little' date=' and some minor (very minor) smoothing of the ports as well. This was also with .060" over sized pistons, which technically made the motor a 2.9L.
The only things I changed to bring it up from 141 to 160hp was switching over to SU carbs and putting in the mild cam (480 lift 270 duration cam), and of course not running a catalyst anymore, these changes were made when I pulled that motor from my '81 ZX and put it into a '72 240.[/quote']
Thats sounds like almost the same setup I am doing with my L28.
Did you regret going to the carbs? (even though u got more HP)
Guest bastaad525
The SU's had both benefits and drawbacks compared to the EFI.
I dont feel the carbs had much to do with the increased HP, rather, I think the extra HP was a result of switching to a hotter cam, which moved the torque range up, resulting in higher peak hp. I really couldn't say for sure if the carbs helped or not, or maybe even hurt performance? Problem is, the EFI in my ZX was never working exactly 'right' either, it had it's bugs, but did put down good power considering the only mod to allow me to really tune it was the adj. FPR, and was running such high compression. Problem is stock EFI really isn't flexible enough on these old cars to really be able to compensate for extreme mods like that. I wouldn't say I regretted switchign over, if only because I was always chasing bugs with the EFI, and the SU's were rebuilt, and so easy to tune and figure out... no wires... no sensors. But the SU's weren't perfect either, gas mileage sucked on the street, and I dont feel the needles that Ztherapy provided with them (SM needles, very popular for this application) were really the 'right' needles... custom needles would have probably helped a LOT.
s'okay I'm right there with ya :)... yeah the 40 extra horses and 65ft lbs of torque are nice... too bad they only cost me like FIVE GRAND!
Yeah well hows it go? Speed costs money, how much you wanna spend?
I always liked the other benefits of the turbo engine. It sounds tame, so people don't expect your car to be fast, you don't break rings revving the snot out of it, you don't have to adjust the valves as frequently, and of course once you are set up, more horsepower is only some good gas and an extra 5 psi away.
Not to mention getting sideways in second gear when the boost hits, now thats what I call fun.
while this conversation is going on, i may as well ask how much power you guys think my car is putting out. I have:
l24 block bored .4over
72 head, ported, and 3 angle valve job
Flattops that are flush with top of the bore
Schooler cam no 483
timing at the 3rd mark, or about 8degrees advanced
straight through exhaust
roundtop su's
k&n's
EDIT: I also have a 6-2-1 header that i seem to have forgotten about.
Thanks
