offset question
Your 15mm offset, on a 7" wheel, would translate into about 4-5/8" back spacing, and as Tim has said, he uses 5" back spacing with a bit of room left between the tire (wheel) and the spring (which is the same case for me as well). With an 8" wheel, you should be safe with a 12mm offset, and with a 9" wheel, a zero offset should still place the wheel back 5". Unfortunately, once you go wider than an 8" wheel, then the fender lip becomes the constraint. An 8" (depending upon the tire used) should not require any fender work, but I'd say a 9" wheel will require the lip to be rolled, if not completely flattened against itself.
