L98 Q's
What's your goal? A 255 hp L-98 from a 90-91 'vette or 245 hp motor from an F-body (same motor, different rating...) would be great in a Z stock. Pocket port the heads, add a cam and lifters along with a spring upgrade and you should be near 300 hp with small tube headers. That should make for a low 13 sec Z car. You really don't HAVE to do anything to put a supercharger on it but buy the kit... With the 9.5:1 compression you would be limited to about 6 psi.
Guest zconvert
v8dats - go with an LT1 man! I agree with you on the looks of the L98, one of the best looking motors going, but personally I think the rumors of L98's being torquier than LT1's are overblown (no pun intended). Also, the gas mileage is considerably better with the LT1. One advantage I do see with the L98 is electronics, they are simpler on the older cars, one 02 sensor, no OBD-II, etc.
Guest Big Phil
I'm currently doing a Lt1 swap, but if I could do it again I probably would have used a L98. Since the Lt1 was only produced for a couple of years, the performance parts are more much expensive. For example several people on the forum are struggling with the A/C and Power Steering delete issue. There are only two companies that offer serpentine pulley systems, both systems retail for over $500.00. Another issue is trying to find angle plug block hugger headers with d shaped ports. I bought mine for $400 from Speed and Performance. An aftermarket wiring harness, cams and upgraded heads are also more expensive. If fact LT1 parts cost way more than LS1 stuff.
I think the Lt1 is a great engine but the extra expenses definitely add up. I say go with a L98 or LS1.
Phil
i was just throwing it out there cause i iknow where i can get an 88 gta at a good price. it has leather interior,4 wheel disc brakes,and those very cool 16 inch honey comb rims.might trade my 86 monte carlo ls for it.i would probably go with an LT1 if anything or a carbed blown sbc :D . just wanted to know what would make this a mustang killer. twak.gifrockon.gif
