ALUMINUM CYLINDER HEADS - BEST?
I have been searching for a crate engine to put in my 77 Z and while I would love the ZZ4, the money is tight. I found at http://www.goautocenter.com a 350 chevy long block with 9.5 compression and the 58cc factory vette aluminum heads for $2295. The beauty of this engine is that for the same price I can get Edelbrock Performer or Performer RPM aluminum heads or the Trick Flow Heads for the same $2295, installed.
:?: The car will be more a daily driver than anything so which of the heads above would you experts on the subject recommend? The engine is supposed to make 320 hp and a little more than that for torque with the vette head (there is a hp and torque curve at the website). The ZZ4 comes with the same vette heads if I not mistaken, so I need a little guidance. BTW they also indicated that I could have the Edelbrock Performer RPM cam and lifters installed for an additional $200. :D
Also, has anyone bought or dealt with this Texas company?
Thanks in advance!
TFS-30400002
these heads (even if they add a few dollars to the total cost) the better springs are worth the cost
http://store.summitracing.com/default.asp?target=search.asp&type=bykeyword&searchtype=both&part=trickflow+heads&x=19&y=7
youll need to tell me the cars gearing,weight,trans, stall, speed,headers size, (do you need to pass emission testing?) (are you going to use nitrous?)ETC, before a cam can be picked correctly
Here are a couple of links for SBC ( and others ) Head Data, notice the trickflow 23 deg heads, compared to the edelbrock performer and vette heads
http://users.erols.com/srweiss/tablehdc.htm
http://www.purplesagetradingpost.com/sumner/techinfo/heads1.html
Thanks Grumpyvette!
I plan on running a T5 with the stock R200 with 3.54 gears. I do not have emission concerns and will be using the car mainly as a summer daily driver with an occasional romp at the track.
With the heads you recommend, besides the cam how about the intake?
For being a novice I was originally going with the complete Edelbrock performer RPM so that I knew the components would work together.
Thanks again for the advice!
