rustorbust Posted February 17, 2004 Share Posted February 17, 2004 If u used 400 pistons, 400 block, 5.7 rods, 350 crank, where would that put the piston. If im not mistaken that would put the piston right at the top of the deck. And is it the same as 377. Give me a little input, i have some extra parts laying around and i was thinking of putting together a budget 377. James B. Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted February 17, 2004 Share Posted February 17, 2004 To answer your question.....Yes & No. Yes 1/2 of 3.48 = 1.74" Crank Throw + 5.7" Con Rod + 400 Piston Compression Height of 1.560 will equal 9.025". This is the length of your Block Deck Height on both the 350 and 400 SBC's: providing your 400 has not been decked. If I'm not mistaken...and I may be: but I believe the side clearance at the big end of the rod's on a 400 have a wider beam than on the 350. This means your 350 rods will be narrower and side clearances will not line up. The 400 crank main also has a wider diameter than the 350 crank main: requiring an aftermarket crank (expensive ) or utilizing spacer bearings on the 350 crank. Someone else a little more knowledgeable on the 377 build up needs to chime in on whether the 350 rods can actually be used in the 400 block. Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted February 18, 2004 Share Posted February 18, 2004 Since this is for a 377, then he will need to use bearing spacers for the 350 crank and no prob. w/the 350 rods. Might want to check the valve reliefs in the pistons and use a thicker head gasket than normal.... Quote Link to comment Share on other sites More sharing options...
rustorbust Posted February 18, 2004 Author Share Posted February 18, 2004 I already have the dished pistons and bearing spacers. I stuck it all together iwth the 400 pistons and i was amazed to see that the piston came to the top of the deck. im glad i dont have to but 377 pistons. James B. Quote Link to comment Share on other sites More sharing options...
