260ZRED Posted March 7, 2004 Share Posted March 7, 2004 When I removed the correct diameter balancer req'd per the JTR manual (less then 7.25 inches), it came apart in three pieces. The outer metal disc with drilled holes got seperated from the inner solid disc, with the rubber gasket which was between the two apparently. Now I have 3 pieces I can't put back together. What have I done wrong? How do I put it back together? I have to put it on my built motor now (also a 350) and am totally lost on how to do it... everything is ready...except this one little piece driving me insane! I tried beating the piece back into "one", but had no luck at all.. my questions are: 1.how do I assemble it again?? 2. how do I install it? What tools what you recomend? thanks for any help. Quote Link to comment Share on other sites More sharing options...
labrat Posted March 7, 2004 Share Posted March 7, 2004 Umm... You don't re-assemble it, you replace it. It's broken. The rubber damping material probably came unbonded from the metal. Happened to me on my '78 El Camino. Got a replacement from the JY and it worked fine. Summit also has some good ones that are fairly cheap, if you're looking to upgrade from stock. Don't install it with a hammer or with the bolt, there is a tool that you can borrow at autozone that is specifically for installing harmonic balancers. Good luck! Bill Quote Link to comment Share on other sites More sharing options...
Tim240z Posted March 7, 2004 Share Posted March 7, 2004 You can't reassemble it. Buy a new one, and buy these tools: Installer tool: Remover tool: Tim Quote Link to comment Share on other sites More sharing options...
260ZRED Posted March 7, 2004 Author Share Posted March 7, 2004 thanks for the info, this was driving me crazy. (spent about an hour trying to beat the darn thing together, I got very close but never just right how it was, lol) thanks again. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted March 7, 2004 Share Posted March 7, 2004 Do what the other guys said and be sure you get the correct tool for installing it! If you beat it on with hammer and wood block you will reck your thrust bearing for the crank! Dont take a short cut on this one.(not saying that you would but I have seen to many guys beat the balancer on) Guy Quote Link to comment Share on other sites More sharing options...
