BillZ260 Posted March 11, 2004 Share Posted March 11, 2004 Is anyone using a fuel cut off switch? If so, what set up? I am thinking a pressure drop that triggers cutting power to the pump. Anyone doing this? My thinking is a halfshaft bites it and it ends up cutting my fuel line. Searched, but didn't see anything. Thanks Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted March 11, 2004 Share Posted March 11, 2004 Most people use one that senses oil pressure. The theory is that the engine quits and the drop in oil pressure shuts off the fuel pump. You hit a tree and the engine quits, which shuts down the fuel pump hopefully preventing a fire. Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted March 11, 2004 Author Share Posted March 11, 2004 I may be over worried but I want to be sure. I could use both, or is it going to be overkill? I ran my 3/8 alum line where the stockers were, through the tunnell and even through the stock mounts. The only difference is where the fule line stayed on the top of the under carage when going across the rear subframe crossmember, just behind the diff, Mine is UNDER The brake line, instead of OVER, like the stock was. nothing should hit it but I am trying to think worse case.... Quote Link to comment Share on other sites More sharing options...
z-ya Posted March 15, 2004 Share Posted March 15, 2004 When I put my aluminum lines in, anywhere there was metal to metal contact, I used rubber hose over the aluminum line to protect it. Put a couple of tie wraps around it to kepp it from moving. If the high pressure line were to rupture, you would probably loose fuel pressure, which would cause the engine to stall, and the ECU would turn off the pump. If the return line ruptured, then you would be spewing fuel until the tank went empty. Pete Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted March 15, 2004 Author Share Posted March 15, 2004 The line is isolated from contact with other metals. I am only running a supply line, carb, and only thinking of a mechanical mishap that severed the line. I guess I will just get the oil pressure swtich and if there is a problem, kill the motor. Quote Link to comment Share on other sites More sharing options...
