Can an L28 distributor be locked down?
Guest Loose_Screws
Guest Loose_Screws
Is it possible to lock down the distributor on my '77? I want to lock out vacuum and mechanical advance completely. I attempted to take apart the dizzy, but unable to get screws to break loose. I just want to check before I attempt to tear it apart.
Yes, it should be possible, but why?
Most people do away with the vacuum, but even hardcore racer types leave the mechanical intact. I JB welded the vacuum advance plate to the breaker plate on my ZX dizzy.
I would think just take the weights off of the shaft and JB weld or safety wire them so that they cannot open would get the mechanical disabled.
Jon
Guest Loose_Screws
Thanks for the info.
I want to lock down the dizzy completely since I am setting up to run Megasquirt/MegaSpark. I guess I could leave the mechanical advance functional, will just have to experiment and see!
