Stub Axle Seals
I don't see a seal in the shop manual or in the Motorsports catalog for a rear stub axle seal for the wheel side. There is one for the differental side, but not a "inner" and an "outer" seal. The ones I took apart did not have one, but also had alot of grit in the bearing area?
Anyone take a rear stub axle out lately?
  Z8 said:
Thanks Pete, I see that the outer bearing has a seal incorporated. But I found alot of grit inside and wondered if it was missing one.
You found grit inside the rear strut housing? or only surficially outside the sealed bearing? If it's inside your bearing housings are likely scored and I'd suggest different struts. I assume though that it's grit outside which is normal and alright.
