8.5" wheels on front: Suspension setup?
I'm gonna be putting 15x8.5" wheels on all four corners of my 260 here soon, with 245/35/15 tires mounted on them. What problems am I gonna run into on the front, in respect to alignment, ball joints, etc.? Should I be anticipating mods to accommodate them? ( BTW, fender and spring clearance is not an issue)
It does seem the extra width is biased toward the outside, because the wheels stick out 2 inches past the stock fenderwell, while still maintaining clearance on the inside. The wheels are the Carroll Shelby panasport type, which I'm moderately sure came off a Z with the full Jim Cook California flare kit. Would the offset be stamped on the wheel, or do I just measure it to find out?
I'd hazard a guess that you'll be about 1" offset here. Not ideal, but it shouldn't cause any bad problems. Depending on your camber adjustment, you may experience some slight steering feedback under braking on uneven pavement.
