LSD intended for S15 240SX
Trevor
Hi Trevor
1- Check the distance from crownwheel mounting face to ends 116mm & 50mm will work with Z gears if 124mm & 42mm it wont.
2- You need the slide in flanges as they are different to Z or VLSD.
3- You have to make custom drive shafts.
These conversions are not straight forward as you can see and there are other LSD units that are made specifically for R180-R200 that use the existing driveshafts and are much easier to do or have done. Neil
