REAR DIFFERENTIAL ???
Guest Jim226
70-73 240Z Manual
3.364 R180 Open
70-73 240Z Auto
3.545 R180 Open
74 260Z Manual
3.364 R180 Open
74 260Z Auto
3.545 R180 Open
75-76 280Z Manual/Auto
3.545 R200 Open
77-78 280Z Manual
3.545 R200 Open
77-78 280Z Auto
3.545 R180 Open
79 280ZX Manual
3.364 R180 Open
79 280ZX 2+2 Manual 4-Spd
3.364 R200 Open
79 280ZX 2+2 Manual 5-Spd
3.7 R200 Open
80 280ZX 2+2 Manual
3.9 R200 Open
79-80 280ZX Auto
3.545 R180 Open
80 280ZX Manual
3.545 R180 Open
80-83 280ZX (Non-Turbo) Auto
3.545 R180 Open
81-83 280ZX (Non-Turbo) Manual
3.9 R200 Open
81-83 Turbo
3.545 R200 Open
79 280ZX Manual
3.364 R180 Open
79 280ZX Manual
3.364 R180 Open
79 280ZX Manual
3.364 R180 Open
3.9 R200 Open
84-86 300ZX Non-Turbo
3.7 R200 Open
84-86 300ZX Turbo
3.54 R200 Open
87-89 300ZX Non-Turbo
3.9 R200 Open
4/87-89 300ZX Turbo
3.7 R200 Clutch LSD
1988 Turbo SE
3.7 R200 viscous coupling LSD
So you can use the diff, but will have to go through the standard R200 swap. More info can be found here.
http://www.geocities.com/MotorCity/Garage/6212/diffswap/diffswap.htm
I don't know the exact limit - I managed to blow the spider gears to bits with a 2.8 W/webers, cam, etc. Of course that was 18 years ago....when that engine was the hot setup. Any serious traction with a big motor could cause problems with the spider gears. A R180 lsd probably wouldn't be bad - as it is probably a 4 pinion unit.
Doug
Guest subdermal
<Slight tangent> - what would be really very useful is a Z diff faq with a sticky on it so that the same questions wouldn't keep comign up. THere are so many combinations that it makes one's head spin. I've been trying to keep up, and I see questions that I've seen a dozen times before and the irritating part isn't that its the same question, its that I still can't remember the answer :P
If a Z veteran (or a few) were to put that together it would be much appreciated by not only myself, but by a vast majority of the members I'm sure. If not, I will write one up as best as I can when I get to that part of 'the project'. It's only fair, since I brought it up ;)
</tangent>
