Nissan SR20DET motor sets.. if anyone is intrested
cyris3d
  • 3 weeks later...
Guest Luv_piece
correction
REDTOP = zenki(early model) S13 SR20' date=' low port head, t25
BLACKTOP = kouki(late model) 180SX/S13/S14, S14 models have VTC and T28(NOT THE SAME T28 AS S15 TURBINE), high port head
S15 has a blacktop engine, different mission (6 gears in the 5 gear mission case speed sensor in rear end), T28 ball bearing turbine and VTC
just wanna make sure you guys are buying the right stuff
as far as poweroutput
its all the same once turbine/camshafts are swapped.
i would get a redtop myself.[/quote']
Kouki S13 blacktop does not have VTC or T28, basically the S13 Blacktop is the same as the S13 Redtop with a few minor differences like fins on the front of the head and a black valve cover. Stock horse power was rated at 205@6000rpm.
Also stock horse power rated for S14 Blacktops were 220@6000rpm vs. S15 Blacktops which rated at 250@6000rpm. The difference between those two where the turbines used. The S15 turbine had a cast divider that seperates the wastegate and turbine discharge.
Guest zline
i never said they did
maybe if you'd read more careful instead of trying to run around and correct me
Guest zunitzx
if your looking for a sr20det s13 red top, i know a site where u can get one for $1250 and thats with shipping included.
»Engine Code: sr20det rwd
»Year:90+
»Valve train: Dohc,16 Valves
»Transmission: Hydraulic
»Displacement: 2L
»Horsepower: 205 HP
»Price:1250$
these are the things included
»Motor
»Transmission
»Distributor
»Intake Manifold
»Alternator
»A/C Power Steering Pump
does this guy bring in RB25DE?
i need to find one asap and am willing to pay rather than wait for my next container.
got a contact number?
ty.
