Cheap hair spray
Guest 305240
Guest 305240
When I was reading the posts on the wiper motors, and other electrical connections corroding, I just remembered something. Keep in mind, this old brain still works, but a lot more slowly than it used to. Back in the Viet Nam war, I used to be a crew chief on the Phantom F-4's. We had to use a spray electrical sealer on every wiring connection. The Can was OD green of course, but the paint scraped off very easily. Low and behold, underneath the OD green paint was a can of cheap aquanet hair spray! I checked more than one can...Same thing...Aquanet. I crewed a Bird for 4 years over there, No corrosion of any kind after using the stuff. I've used it on my cars also. It's nice to know that if you hit a big water puddle your engine isn't dying out on you. Hope this helps someone.
Guest 305240
All I know is that it works. I spray it on my dizzy and plugs, all my wire connections and terminals. Including the alt. I used it on my 5th wheel gang plug. Any place where I need a good clear sealer. Hey, I figure if the USAF uses it on multi million dollar aircraft, why can't I use it on my car?
cant you use that stuff as a release agent when doing composite stuff? A guy at the local composite store told me that but I just couldnt bring myself to believe him.
maybe he was right?
I think that is the stuff you spray in you frying pan. Up here we call it Pam.
