valve clearance for stock iron
If it is stock then it should have hydraulic lifters. If this is the case then you tighten the rockers to take up all slack (friction felt when turning pushrod) and go another 1/4 to 1/2 turn depending on who you talk to. You need to make sure that the lifter is not on a lobe. Any Chevy V8 manual should give full instructions. You can also set them with the engine running if you control the oil with deflectors or valvecovers with the top cut out. I always set them at 1/4 turn past zero and then readjust them running once the engine is warmed up.
