Extremely Strange Problem !!!
In addition to the problems I'm trying to work out, I noticed while the enging was cranking during the compression test, the hydraulic line from the clutch slave cylinder to the master was getting extremely warm to the touch!! Any ideas why??? The motor is yet to be fired ! It is an Earl's braided hose exactly what JTR recommended.
:D Without a doubt a bad ground. I ran in to this problem years ago on a 68 Camaro. My throttle linkage would get hot and spark everytime I cranked the motor over. To solve make sure your negative cable goes right to the starter or even block, to a bare metel surface.(not painted). can also add braided ground strap or straps from engine to body!! GOOD LUCK!!!!!!!!!!
