window register tune up
BillZ260
I need to tune up the register in my drivers side door. I have never messed with one before. Currently you have to pull up on the rear of the window to smoothly roll it up. Any tips or suggestions would be great.
I also need to replace the inner felting, is there a good supply source or are they all about the same. Seen some on ebay, guess I will comparison shop.
thanks
Guest 305240
After you clean all the dirt and grime out of the regulator, I would use a white lithium grease on the gears and joints. Victoria British or MSA should be a good sourse for the rest of your needs.
Here is the window felt I used... cheap and easy to get!:
http://www.jcwhitney.com
> The catalog item number for the part is 18GA-4874U.
> Now here's the tricky part. The letters in the catalog number can be
> different depending on which issues of the JC Whitney catalog your looking
> at. But if you call the order line and tell
> the person you want part # 18-4874, you'll get the right stuff. It's
> description is "Rubber Window Channel 9/16 " x 17/32 ". It comes in an
8-ft.
> piece. Which is almost enough to do
> both sides, but not quite. So, you have to order 2 pieces. The price when
I
> ordered was $6.99 each.
