Toysport Posted May 2, 2004 Share Posted May 2, 2004 hi guys........my sbc has a standard size pistons. its going to a machine shop next week increasing the bore to +25..........will i need to replace the crank? what size pistons will i get? the piston rods looked to be in good shape, can i still keep use them? appreciate the help guys. -thanks- john Quote Link to comment Share on other sites More sharing options...
Tim240z Posted May 2, 2004 Share Posted May 2, 2004 Hmmmm...I think that before you do anything else, you should get a couple of books on rebuilding SBC engines. Your questions are not very lucid. Look in the Summit Racing catalogue and there are some good ones, esp. the one by the late John Lingenfelter. But, in answer to your questions, the bore size has next to nothing to do with the crank shaft. 2nd, inorder for the machine shop to bore your block, they will need the pistons, so you will have to buy those first. I would suggest that you remove everything from the block, and take the block and the crank to the shop. Ask them to inspect and measure the crank to see if it needs to be cut, or if a polish on the journals will suffice. Also ask them to measure and inspect the bores. They may need to bore it to the next oversize, in which case they can tell you which size pistons to buy, or they may be able to just clean it up with a hone job....and then tell you which pistons to buy. Take the rods in too, and ask them to shot peen and magnaflux them, or just buy some new ones.....stock replacementr rods are cheap..... Also, ask them to remove and replace the cam bearings... Tim Quote Link to comment Share on other sites More sharing options...
Toysport Posted May 2, 2004 Author Share Posted May 2, 2004 thank you. obviously i have no knowledge to any of this.......fortunately i get good advise from this forum. john Quote Link to comment Share on other sites More sharing options...
Tim240z Posted May 2, 2004 Share Posted May 2, 2004 Do yourself a huge favor and educate yourself a little bit...get a book.....it will give you a better understanding of what you're doing, and you will be better off for it! Quote Link to comment Share on other sites More sharing options...
Toysport Posted May 2, 2004 Author Share Posted May 2, 2004 thanks again Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted May 3, 2004 Share Posted May 3, 2004 http://www.chevytalk.org/threads/showflat.php?Cat=&Number=713945&page=0&view=collapsed&sb=5&o=31&fpart=1 look this over you need to buy and read at a ABSOLUTE MINIMUM books 3, 4,and 5 on the list Quote Link to comment Share on other sites More sharing options...
Toysport Posted May 3, 2004 Author Share Posted May 3, 2004 thanks. i ordered "how to rebuild sbc on a small budget. Quote Link to comment Share on other sites More sharing options...
jt1 Posted May 3, 2004 Share Posted May 3, 2004 Grumpy and Tim are right. Vizard's "How to rebuild your SBC", and the first book in the link, "How to Hotrod your SBC", are excellent. You'll understand a lot more after reading them, and there's a lot of references about torques, torque patterns, etc., that are very useful. John Quote Link to comment Share on other sites More sharing options...
Toysport Posted May 3, 2004 Author Share Posted May 3, 2004 thanks guys.......i tell ya i am anxious to read this book.....i should have in a few days. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted May 3, 2004 Share Posted May 3, 2004 you need to buy and read at a ABSOLUTE MINIMUM books 3, 4,and 5 on the list HOW TO BUILD MAX PERFORMANCE CHEVY SMALL BLOCKS ON A BUDGET by DAVID VIZARD . JOHN LINGENFELTER on modifying small-block chevy engines how to build & modify CHEVROLET small-block V-8 CAMSHAFTS & VALVTRAINS BY DAVID VIZARD SMOKEY YUNICK,S POWER SECRETS trust me it will be the best money you ever spend!!! Quote Link to comment Share on other sites More sharing options...
