Q about 305 in my truck
Guest TM240Z
Non Z related. I just bought a 83 chevy 4X4 305 to drive in winter. When its cold it has a dead spot at part throttle,like there is no gas going in. When it's warm it runs great.The truck is stock. Would this likely be a vacuum problem or something like the accelerater pump?
Typical carburetor. Probably something do do with adjustment of the choke or its enrichment. Stupid amount of vacuum controls on those models. Is it ESC also? Sometimes a tuneup (plugs, wires, cap, rotor) will cure some of those ailments. Also check the air-preheater from the manifold and make sure the vacuum port is working on the air cleaner.
