Guest MC_jr Posted May 13, 2004 Share Posted May 13, 2004 i know how to mount it and everything, im just not sure what i need? is all i need is a fuel sell with sender built in? all the ones i see have only gm senders. what did everyone else use? Quote Link to comment Share on other sites More sharing options...
datsunan Posted May 13, 2004 Share Posted May 13, 2004 I'm using a summit alum cell. It came with a GM sending unit that is supposed to work but not be exactly accurate. I have yet to get it be even close. I also mounted it with the sump pointing foword because I did'nt want the lines coming out the back. When I launch my car boggs if I have less than 2 gallons in the 15 gln tank, so don't mount it like me or you'll be remounting it like me. Paul Quote Link to comment Share on other sites More sharing options...
Guest MC_jr Posted May 13, 2004 Share Posted May 13, 2004 what about venting it and stuff? also should i replace the lines even though im gonna be going v8 soon? wont i haev to change lines...again. Quote Link to comment Share on other sites More sharing options...
datsunan Posted May 13, 2004 Share Posted May 13, 2004 I'm running a 350hp 280 turbo on stock lines but I don't know if you will need to replace them for a v-8. If your v8 is going to have more than 350hp you might need bigger lines it would'nt hurt. You will need to vent it or you will pull a vaccum in the tank. Just run a line off the top out of the car to atmosphere. Quote Link to comment Share on other sites More sharing options...
