Guest JAMIE T Posted May 16, 2004 Share Posted May 16, 2004 The obvious would be Chevy inlet and outlets, but... My Z28 has the inlet and outlet in the Ford positions. I guess what ever works but, what did you guys use? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted May 16, 2004 Share Posted May 16, 2004 I'm using the camaro radiator (4 cylinder I think), aluminum with plastic tanks. I believe it's the same one suggested by JTR. Coming back from MSA, it must have been at least 100*F outside and I had no problems! Tim Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted May 17, 2004 Share Posted May 17, 2004 I'M USING THE JTR RADIATOR AND MOUNTS. LOOKS NICE!!! Quote Link to comment Share on other sites More sharing options...
innerware Posted May 17, 2004 Share Posted May 17, 2004 jtr mounts and radiator. Looks awesome and was easy to install. I still have my 6 though. But am preparing for the 8. He has new mounts and radiator so contact him. I can post pics if you want. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted May 18, 2004 Share Posted May 18, 2004 Just for reference: I made my own lower mount (similar to the JTR one I think), and I used a 6 Cylinder (I think) Camaro top mount and fan.... Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted May 18, 2004 Share Posted May 18, 2004 I have exactly 25-3/4" between my frame rails. I replaced them completely with 2-1/2" square tubing. I did not notch them like the factory frame rail is, but I did widen the frame rails slightly. How wide is the 4cyl Camaro unit? My JTR book is at work. Does it give dimensions? Quote Link to comment Share on other sites More sharing options...
