How much is too much end play?
Phyte
lets get something cleared up here. end play is the movement from the turbine wheel froward and backward in the turbo. The exhaust wheel and turbine wheel is on the same shaft.
Runout is the movement up and down in the housing.
Turbo,s for ther most part have runout due to the bearing configuration. end play should be very minimual, not more then a couple thousands at the most.
