60 mm TB help
DAT240Z
I'm trying to install my 60 mm TB but have run into a problem. I remove the spring and shafts from the old turbo intake, went to install the return spring and notice that the lever for the return will not bolt up the 240sx TB, how have you guys that have done the swap over come this problem?
I think I may ahve posted this in the wrong forum.
