Will the heat from the turbo cook these? (pics)
sims76
This is for the MSnS turbo project I'm working on...
To aviod running wires all the way into the cockpit, I mounted the MSD box and HEI module right above it on the fender. I did mount the HEI to a heat sink that also serves as the ground. Opinons? Will the heat from the turbo cook these?
I also made a simple heat sheild out of sheet metal to protect the brake master and the terminal strip that I mounted there.
The turbo should be shipped tomorrow. I know I said I would be finished in two weeks about two months ago, but this time I mean it.
Thanks guys,
Sims
Guest bastaad525
agreed, move the box...
I put my MSD box against the driver side fender wall but back under the 'battery inspection cover' (except no battery on the drivers side of course!), near the brake and clutch cylinders. My wiring runs right near the turbo to get to the coil.. so far no problems there.
Thank you all...
I like the driver's side windsheild cowl idea the best. Will look into the fender wall under the battery cover as option #2.
This gauge is patiently waiting...
240sx TB from JeffP with JSK Spacer and Pallnet o-ring fuel rail (not shown)
