Mike C Posted June 21, 2004 Share Posted June 21, 2004 Anybody have the torque for the 12mm R200 ring gear botls? My service manual is for a 76 so only 10mm! Thanks. Also, anybody have a single R200 stub axle that is not part of a matched pair or that the flange is damaged on? I'd like to get one to put in the vise to hold the diff while I torque ring gear bolts. Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted June 21, 2004 Share Posted June 21, 2004 http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=34051 LARRY Quote Link to comment Share on other sites More sharing options...
Mike C Posted June 22, 2004 Author Share Posted June 22, 2004 Thanks for that link. Didn't think it had been posted before. As an aside, I have never seen such liberal application of Locktite! I wire brushed the ring gear bolts and did my best to clean out the gear. 12mm 1.25 pitch, same as the Z wheel studs (which is the torque spec I was going to use from the book, should be same.) but my tap and die set only had 12/1.5 and 12/1.75. And as usual, I had a better selection of tools than Sears... Quote Link to comment Share on other sites More sharing options...
