ZR8ED Posted June 21, 2004 Share Posted June 21, 2004 Hey all. I've been pretty busy with work lately and I have been having trouble finding time to surf here. The Z is still alive. The Merkur injector swap into my VG30ET is complete. The reprogrammed ecu is in, and the car fired up on the first turn of the key. I found some electrical gremlins and a minor vac leak while doing the inj swap... it is running even better now. I have the boost set the same, while I ensure the air fuel ratios are ok...The boost will get cranked though..don't worry about that! The fuel pump is rewired finally, nice 10 guage wire, direct to the battery, with a slick relay. I have started to fit the rear belly pan to the car. It is getting modded a bit, and it will now hide the gas tank. It will be a few more days before I can finish it up. I looks mean when it is just put into place! I'll have plenty of under car pics. It sure will be fun to test the belly pan out eh? Don't worry.. I remember.. 7-9 degrees.. hehehe. Custom work is a joy isn't it? hehe Oh.. and the 240 just sits waiting for its turn.. Quote Link to comment Share on other sites More sharing options...
Synlubes Posted June 22, 2004 Share Posted June 22, 2004 I have started to fit the rear belly pan to the car. It is getting modded a bit, and it will now hide the gas tank. It will be a few more days before I can finish it up. I looks mean when it is just put into place! I'll have plenty of under car pics. Looking foreword to the pics! Quote Link to comment Share on other sites More sharing options...
mtcookson Posted June 22, 2004 Share Posted June 22, 2004 I'm definitely looking forward for the completion of this. I might be getting a 280Z myself and have been a fan of the VG30ET engines so I was planning on swapping it into there. How hard was the swap? Pretty much just a lot of fab work? Quote Link to comment Share on other sites More sharing options...
