grumpyvette Posted June 23, 2004 Share Posted June 23, 2004 I think youll find these very handy if you work on cars and don,t have a lift BTW the 12 ton stands are PREFERED as they have a WIDER BASE and EXTRA STRENGTH,(if IM GOING UNDER A CAR I DON,T WANT TO BENCH PRESS THE DAMN THING TO GET OUT FROM UNDER IT) how much is you LIFE WORTH,BUY THE !12 ton RATED STANDS they are MUCH safer than the 3-6 ton stands IF ONLY BECAUSE THEY ARE FAR HARDER TO TIP OVER IF SOMEONE ROCKS THE CAR! 2 Piece Set These super heavy duty jack stands will hold most cars and trucks safely over 2 feet off the ground. Perfect for repair work or storage. Height: 19-1/2'' to 30-1/8'' Base: 12'' x 12-1/2'' Weight: 68 lbs. THIS ABOVE IS RIGHT OFF THE HF WEB SITE http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=34924 second, thing is IVE used a set of four very similar 12 ton jack stands from NORTHERN TOOL for years, with no problems what so ever , and when they are in their low setting they are at about the right height to allow you to work under the corvette http://www.northerntool.com/webapp/wcs/sto...19&categoryId=0 Torin Pair of 12–Ton Jack Stands 2 heavy–duty steel jack stands at one low price! Double locking pawl and tooth design for extra protection. Minimum height is 18 1/8in. Maximum height is 28in. In Stock Ship Wt. 63.0 lbs Item# 144872 Discount Price... $64.99 Sale Price... $54.99 110% Guaranteed Lowest Price! youll be getting them at a significant discount if they price match, which they should Quote Link to comment Share on other sites More sharing options...
Guest plainswolf Posted June 23, 2004 Share Posted June 23, 2004 they have a WIDER BASE and EXTRA STRENGTH,(if IM GOING UNDER A CAR I DON,T WANT TO BENCH PRESS THE DAMN THING TO GET OUT FROM UNDER IT) Now that alone would would be worth it! Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted June 23, 2004 Author Share Posted June 23, 2004 OR ..IF you don,t use good jack stands like this guy.........YOU could change this picture into a poster........... TITLE " how to get killed useing your corvette without even starting the engine!" Quote Link to comment Share on other sites More sharing options...
Guest plainswolf Posted June 23, 2004 Share Posted June 23, 2004 Grumpy what the heck makes the C4 vettes so heavy? I know they are a full frame car but do they have anything like the Z car bumper weight in their design? in fact how do their bumper work? are they a crush zone? Don't get me wrong I LOVE vettes! was just curious though.. especially of the C4 series Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted June 23, 2004 Share Posted June 23, 2004 "Jim Bob changes his muffler bearings" But seriously, if that person had the cash to buy that 'Vette, don't you think they would invest in some decent jack stands and a jack? !M! Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted June 23, 2004 Share Posted June 23, 2004 Grumpyvette: Already have 'em! They ARE STURDY.... Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted June 23, 2004 Author Share Posted June 23, 2004 my c-4 corvette weights about 3300lbs without me in it, the reason I use those jack stands is that the wider base prevents tipping and they are MUCH stronger than the 3-6 ton size,if youve ever worked with other guys youll sooner or later see someone lean on a car while its up on jackstands and if its useing those flimsy cheap 2-3 ton stands chances are great that the car moves some, the 6 ton are better but not nearly in the same class as the 12 ton models Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted June 23, 2004 Share Posted June 23, 2004 Got those too! Quote Link to comment Share on other sites More sharing options...
