namz7791 Posted June 24, 2004 Share Posted June 24, 2004 I have an 88 Chevy 350 and yes it is actually in the car . Used the JTR set up and am now working on the cooling. The JTR Camaro radiator doesn't have a nipple for the heater return line so they recommend using a T in the bottom radiator hose. I remember that the older Chevy's use to have a heater hose out of the water pump and then one out of the intake. The long water pump out of the 88 Burb had the top pipe thread plugged since the heater hoses attached to the radiator and the intake. Can I just take out the plug and insert a nipple for one of the radiator hoses? If so which out let should go into the heater core and which will act as the return? I don't want to have both hoses fighting each other with the flow at the heater core or it will never heat up. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
jt1 Posted June 24, 2004 Share Posted June 24, 2004 You can just take out the plug and put a nipple in the water pump no problem, that's the way mine is set up. As far as I know, it doesn't make any difference which way the water flows thru the heater core. John Quote Link to comment Share on other sites More sharing options...
72zcar Posted June 26, 2004 Share Posted June 26, 2004 As far as I know, it doesn't make any difference which way the water flows thru the heater core. Is this true, I'm getting ready to hook mine up also on 327... I have a nipple on my pump and a nipple on the intake..mmmm nipples Quote Link to comment Share on other sites More sharing options...
deMideon Posted June 28, 2004 Share Posted June 28, 2004 It doesn't make any difference which direction it goes? That would make it easy, that was a question I have been trying to figure out! Quote Link to comment Share on other sites More sharing options...
