Guest Anonymous Posted December 5, 2002 Share Posted December 5, 2002 I recently purchased a '73 240z convertible with a chevy 350 and need to have the stock tach. calibrated to work with the V8. Contact info on various companies that do this would be appreciated. I'm in the Va. Beach, Va. area, but would send out if necessary. I'd also like to converse with anyone with knowledge of the V8 swap to see if there's anything I can do to improve the car. Thanks for the help. Mike Quote Link to comment Share on other sites More sharing options...
Mike C Posted December 5, 2002 Share Posted December 5, 2002 Buy the JTR (Jaguars that run) book. Will save someone here from Repetitive Stress Syndrome! They tell you how to calibrate the stock tach. FYI, if you have electronic ignition you will need to swap in the guts from a 280Z tach. The JTR manual will answer hundreds of little questions about the V8 swap and is a very useful reference source for brake and chassis mods as well. Quote Link to comment Share on other sites More sharing options...
