240zprace Posted July 10, 2004 Share Posted July 10, 2004 i'm helping my buddy convert his 74 260 to a zx distributor with 12-80e one. need to know where all the wiring goes. if anyone has done this conversion, please help a Z'er in need of expertise. thanks..... Quote Link to comment Share on other sites More sharing options...
datsunlover Posted July 11, 2004 Share Posted July 11, 2004 I got this from a web site a few months back, and copyed this piece of text for myself. I to did the zx dizzy swap, and it takes about 10 minits of staring at it and figuring out to get it to work. Pretty easy actually. I cant remember who's site this came from though.. if they see this, thanks a lot and I hope you don't mind me posting it here! Take the wire that was originally going to your points (from the minus pole of the coil) and connect it to the C connection on the outside of the ignition module. Then run a second wire from the B terminal on the ignition module to the plus connection of the coil. The connection to the balast resistor from the coil should allready be there. Now, just short out the balast resistor. I left mine in place and simply ran a wire between the two connectors. Hope this helps. Quote Link to comment Share on other sites More sharing options...
