worth the extra cost or not?
Guest tejas74260
Guest tejas74260
hey guys, ive been shopping around for coil-over suspension set-ups. mainly ive been comparing the modern motorsports coilover system to the MSA race setup. (ive also considered dave's arizonazcar coilovers.) the thing i liked about the MSA setup is that it not only provided a large ride height range and camber angles, but it also can adjust caster angle as well (good for the strip when you wanna run positive caster) so do you think it would be worth the extra cost? (i dont mind spending the money for it if there is a somewhat significant advantage. plus im 17 and am rather carefree with my spending :D ) what do you guys think? or is there another alternative that you suggest? just in case its needed my tire sizes are 235/60/15 up front and 245/60/15 out back. thanks a lot.
Mark
MSA coilovers
http://www.zcarparts.com/store/merchant.mvc?Screen=CTGY&Category_Code=PSDC09
