Car won't start
Guest SoCalRacer
Guest SoCalRacer
I recently bought a 240Z with a blown headgasket. OK so i fixed the head gasket problem yet it doesn't want to start :evil: Anyways it's got fuel, spark, but doesn't want to start. It just cranks and cranks.
Check the rocker arms on #1 cylinder against the timing mark on the crank. At one top dead center both valve should be closed at the other exaust valve should be closing and intake opening, both are open slightly. That will check the cam timing. The distributor can be 180° out. Switch your plug wires 180° and try that.
