S15 or late (1998) s14 wiring diagram?
Guest FullBoostOrBust
I have a 1998 SR20det, I have read that it is diffrent from the earlier S14 engines pinout and wiring wise. The 1998 S14 book seems completely unobtainable. I am having the feeling and some facts that it is the same engine wiring as the S15. Since i know i'm in no way finding a 1998 S14 wiring diagram, can anyone help with me finding a S15 one??
specs on the engine:
RB26DETT
T88 34-D.Turbine.Kit
HKS.1.2mm.Dragger.Head.Gasket
HKS.280/280.10.3mm.Cams
Tomei.Valve.Retainers
Sub.Zero.Custom.Intake.Manifold
Q45.Throttle.Body
Jun.Full.Port/Polished.Head
HKS.87mm.Pistons
HKS.H-beam.con-rods
Jun.balanced.Crank
Jun.Oil.Pump
Greddy.Type.R.Blowoff
Blitz.3-Core.Front.Mount.Intercooler
Oil.Cooler.Kit
Oil.Relocation.Kit
Catch.Can
720cc.Injectors
Trust.Fuel.Rail
Aeromotive.Fuel.Pressure.Regulator
the below pic is the engine in the car i pulled it out of. I'm going to go thru it and check everything before running it hard.
couple of links to some vids too
http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=35102&highlight=
Wow, Greddy T88 huh? we have a lot of supras out in New Jersey running T88's, they are barley streetable and lay down around 800+ rwhp! 9's should be easy for you :) Good luck man! :-D
  • 3 weeks later...
Just for any future searchers out there, I succsessfully used a S15 ECU wiring diagram to start my Late 96-98 S14 engine. This was done by simply hardwiring my own fuel pump lines and ignition, then powering/grounding the ECU. Started right up. I was expecting it to be much more difficult then that but it wasnt.
  • 2 years later...
