Pop N Wood Posted August 6, 2004 Share Posted August 6, 2004 Another trick I learned is to get some extra tranny bolts, cut the heads off and turn them into alignment studs (use a hacksaw to cut a screwdriver slot). Thread one on either side and use them as transmission hangers while you wiggle and align the transmission. Holds the weight of the transmission and ensures it is properly centered. Once you get the other bolts in, use a screw driver to remove the alignment studs. I grew up too poor to afford a floor jack, let alone a jack just for transmissions. Quote Link to comment Share on other sites More sharing options...
