dashboard lights
73_240z
Oh, come on! It's not THAT bad. If no lights at all are working, you might start by looking at what's common to everything. The dimmer switch, the headlight switch itself, fuse, etc.
Take your multimeter and a copy of the wiring diagram and work your way backwards until you find where the interruption is. It's not THAT complicated a circuit, and it would look 10x better than cobbling something together.
The first thing I'd look at, if I were you, would be the headlight switch. They're known to break the solder on the joints after 30+ years. Mine did.
Good luck!
