FEnatic Posted August 18, 2004 Share Posted August 18, 2004 Just wondering if the 260 intake is worth the swap. I have a dual 70 SU 2.8 with a 5 speed. soon to have a header and cam. should I lok for one? Thanks Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted August 18, 2004 Share Posted August 18, 2004 Only if you can get one cheap. We've all heard the claims that they make 10hp more over the stock 240 intakes, but no one has proven it thus far, at least that I know of. However, I will say this, there is one big, proven advantage that *I* personally noticed when I switched over to the 260 intake, as well as many other guys I've talked to who have gotten the same results. With the 240 intake I noticed that my cylinders did not run even... it was a while back now so I forget which way it was, but it either ran leaner or richer on the #'s 2 and 5 cylinders, than on the other four cylinders. After switching to the 260 intake, this problem went away, and all six plugs looked identical whenever I checked them. I can only imagine this would increase power at least a little bit, and provide a smoother running, more efficient engine. I believe I paid about $50 for the 260 intakes. You may be able to find them in a junkyard for real cheap. Quote Link to comment Share on other sites More sharing options...
Guest PR0ject datsun Posted August 18, 2004 Share Posted August 18, 2004 what code is the intake manifold? Quote Link to comment Share on other sites More sharing options...
FEnatic Posted August 19, 2004 Author Share Posted August 19, 2004 right now I have an E-46 intake, whicj I assume is a 70 Quote Link to comment Share on other sites More sharing options...
johnc Posted August 19, 2004 Share Posted August 19, 2004 This is the definitive thread on this topic with seprate dyno tests witnessed by me on the west coast and Keith Thomas (katman) on the east coast. http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=14107&highlight=n36 Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted August 21, 2004 Share Posted August 21, 2004 N36 is the code for the 260 manifolds, is it not? Been a while... Quote Link to comment Share on other sites More sharing options...
Guest rick458 Posted August 28, 2004 Share Posted August 28, 2004 is there a good way of disconnecting or bypassing the throtttle hold open solenoid? that thing drives me batty when I stop at stop signs etc. Quote Link to comment Share on other sites More sharing options...
johnc Posted August 28, 2004 Share Posted August 28, 2004 What does that question have to do with this thread? Quote Link to comment Share on other sites More sharing options...
