Ford Taurus Radiator Fan Motor
Guest Anonymous
Yes, all good info. Here is a shot of that fan mounted on the van radiator. I liked the factory look so I used the plastic top mount from the f-body. The radiator is all rubber mounted with the oem rubber. JY parts, cost me $80:rad $40, fan $40. Easy install with the JTR lower mount (lower it another 3/8" so your cap clears the hood). Only thing else you need to mount the fan is a simple piece of sheet metal bent into a Z shape to attach it on the drivers side.
Guest Anonymous
Mike,In addition to Ryan, my notes indicate that Dan Juday maybe a source of info on what "cooling" works (a search function may be appropriate). Dan has some good installation pictures.The official "JTR" radiator has apparently been changed to a 1985-92 Full size Chevy van 4.3 Litre V6 since the Camaro radiator is fairly extinct. My notes also indicate the electric fan from a 1986-95 Taurus Sable,86-94 Lincoln Continetal, 94-97 T Bird and there are 1 and two speed versions.
