dilop Posted September 10, 2004 Share Posted September 10, 2004 Hey guys need your help here please. I finally got the money to get a Turbo. I did a lot of research and I think I will go with a T04E 50 trim (based on comments, math and flow maps). I was looking at http://www.speedshopthagard.com/turbo/turbo_index.htm and I found that there is a: T3/T04E TURBINE SPECIFICATIONS: T3 .48 A/R Housing or .63 A/R Housing or .82 A/R Housing Stage III Turbine Wheel COMPRESSOR SPECIFICATIONS: TO4E Housing .60 A/R Housing With 3 Inch Inlet 50 Trim TO4E Compressor Wheel 57 Trim TO4E Compressor Wheel 60 Trim TO4E Compressor Wheel Compressor Flow: 46 lbs/min (50-trim) Compressor Flow: 50 lbs/min (57-trim) Compressor Flow: 53 lbs/min (60-trim) and a: T4/T04E TURBINE SPECIFICATIONS: T4 .58 A/R On-Center Turbine Housing or .70, .84 and .96 A/R Tangential Turbine Housing* 0 or P Trim Turbine Wheel COMPRESSOR SPECIFICATIONS: TO4E Housing .60 A/R Housing With 3 Inch Inlet 50 Trim TO4E Compressor Wheel 57 Trim TO4E Compressor Wheel 60 Trim TO4E Compressor Wheel Compressor Flow: 46 lbs/min (50-trim) Compressor Flow: 50 lbs/min (57-trim) Compressor Flow: 53 lbs/min (60-trim) What is the best for my L28E? What turbine and turbine A/R is better for my set up? (megasquirt, custom exhaust manifold, custom fuel rail, aftermarket injectors, NPR I/C(Just Buy it )and soon Electromotive HPX ignition and custom intake manifold.) Thanks and Regards from Costa Rica. Quote Link to comment Share on other sites More sharing options...
Clifton Posted September 12, 2004 Share Posted September 12, 2004 I would get the 60-1, and at least the stage 3 .63. An O trim with a .70 isn't that bad on the street either, haven't tried a P trim yet. It depends on what psi you plan on running and if you don't mind the trade off of a little more lag for more power. If you go full T4 you will need to weld on a T4 flange and use an external wategate. Quote Link to comment Share on other sites More sharing options...
