qwik240z Posted September 15, 2004 Share Posted September 15, 2004 I posted this under the Fuel Delivery forum but I thought I would also post it here: After Tim showed us his "el Cheapo Surge tank " I did some looking around and I found a guy that will make a surge tank for you for around $85 plus shipping. I found him on eBay and he was selling this: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7917340846&category=33602 It looks like good quality and the welds look nice. I wrote to him and asked if he could make one to my specs and here is his reply: "Hi, I was wondering if you could make a surge tank similar to this one you advertise but for use as a fuel surge tank? You can see what I am talking about if you check out this website: http://www.sdsefi.com/techsurge.htm I would be interested in one for my current project. If you can do it, since it is similar to the tank you already make but it would have 4 fittings on it, How much would it be? Thanks for your time. David David, Yes, I can fab a tank for you. Since my tanks use 1/2" thick end caps, I can put three 1/4" npt threads on one end and 1 on the other. If you'd rather have bungs welded on the sides, I can do it that way, too. The price would be around $85.00 plus shipping. If you need it polished, it would be another 15 or 20 dollars. Let me know what you want to do! Brian" Here is his email address: fritz7987@ev1.net I hope this helps someone out there. I told him that I would share this info with the Hybrid Z list and he welcomes our business. For my project, I just picked up a baffled, fuel injected gas tank from a 76 280Z that I plan to install instead of using the surge tank and the 2 pump method. I will try this first and if it doesn't do the job, I will have this guy make me a surge tank and add it later. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted September 15, 2004 Share Posted September 15, 2004 Good info...Thanks Dave Quote Link to comment Share on other sites More sharing options...
baddriver Posted September 15, 2004 Share Posted September 15, 2004 I'm planning on using the Perma-Cool Fuel Filter and Water Separator Kit from Summit, part number PRM-81794. It's a high capacity fuel filter with dual inlets and dual outlets (perfect for the JTR type setup) plus it's a filter, and has a drain petcock on the bottom. And it's only $35. I've already got one, and I checked, I can get replacement filters for it for $4 at the local farm & fleet, plus all I need to adapt it to any size hose is a couple of hose barbs that fit 1/2" NPT threads. I think It's a good system. One thing I'm doing to make it a resevoir, instead of just a filter, is extending the internal pick-up tube to the bottom, right now it only goes down about 1/4 of the way. But there is a nice thick piece of the housing that I can cut threads into, and just screw on a nipple and short section of tube. Quote Link to comment Share on other sites More sharing options...
