Guest jens Posted January 19, 2003 Share Posted January 19, 2003 That engine codes is there on a 165 hp 350 from a 75-76 elcamino and there do i find them on the engine. Is it a factory 4 barrel and has it hei ignition. Quote Link to comment Share on other sites More sharing options...
Mike C Posted January 19, 2003 Share Posted January 19, 2003 The front of the cylinder block deck, on the passengers side, you will find a serial number and a 3 digit code that IDs the motor (behind the alternator if it is still attached). Post the code and I'm sure somebody will verify. If the motor has ever been decked, or possible even if it was surfaced, this number may be gone. You can use the casting number to verify displacement (above the bellhousing mounting area on rear of block.) and casting dates to verify year, but not specific application. Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted January 19, 2003 Share Posted January 19, 2003 Check this site for block and head casting numbers. http://www.mortec.com/castnum.htm Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 20, 2003 Share Posted January 20, 2003 Any SBC experts out there on a Sunday evening..Need help here..Ok..I have a 3970010 SBC 350 with the code VO5O3CKH on the passenger front of the block that would be behind the alternator. SO it is: Flint, May 3.. what does "ckh" mean... also it has a "010" raised stamp mark on the rear of the block inside the bellhousing perimeter. I have never removed the pan but I suspect it is a special high nickle 4 bolt main engine. The engine was given to me Quote Link to comment Share on other sites More sharing options...
Mike C Posted January 20, 2003 Share Posted January 20, 2003 CKH is the 3 letter code that says what application the engine was originally installed in. My book is out in the shop, so I can't say what wpecific application was. The 010 on your motor shows it is a 1% tin/ 1% nickel block. If there were two numbers, 010 and a 020, shows a 1% tin and 2% nickel block. The 3970010 was available either way and in two or four bolt configuration. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 20, 2003 Share Posted January 20, 2003 Thanks Mike... if you get a chance check what CKH means.. Moretec is kind of silent on this Quote Link to comment Share on other sites More sharing options...
Mike C Posted January 21, 2003 Share Posted January 21, 2003 CKH 1972 CKH 307 Powerglide 1302 F A X/Apollo/Ventura 1973 CKH 350 m/t, 4 spd, NB2L48 1754 F A X /Chevelle/Monte 1974 CKH 350 m/t,3 & 4 spd, NB2 L48 160 4 F A X http://www.nastyz28.com/sbchevy/spcode2.html Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 21, 2003 Share Posted January 21, 2003 Thanx again Mike... seems it is a car 350 engine,manual tranny ,emissions,4 barrel with 160/170 hp. I copied a lot of pages from nastZ28.com Quote Link to comment Share on other sites More sharing options...
