Guest ON3GO Posted September 16, 2004 Share Posted September 16, 2004 well its at 8-10psi and im loving it. i got a early birthday gift from my uncle. got this.. heres the specs: http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=4349&prmenbr=361 also got a 16inch electric fan too, best part was Jegs threw in a JAZ overflow bottle with the deal!!! was happy about that my friend also just made his own Alcohol injection system for his turbo volvo so im thinking about putting one on the blue Z to try it out. gonna raise the boost abit higher once i put the MSD 6-BTM unit on and the Blaster 2 coil, and new NGK-R plugs. if i can get the guy who i bought my used slicks from on the phone ill have them too on some stock steelie Z wheels. also ill be putting in some new black carpet in it (so far its half out and on has one seat ) and ill be redoing some of the wiring i found under the dash that was a mess. also on the way home from school i was playing around with a new evo. red and pretty! he was stock and from a 2nd gear punch i just barely beat him by a car or so! boost was spiking to 11 and staying around 9-10. from a stop i would have lost.. that i know but i was all happy! anyways i need to say thanks to Chris again for helping me figure out my problem with the Z... its now working 99% great, small miss but nothing bad at all! mike Quote Link to comment Share on other sites More sharing options...
80LS1T Posted September 17, 2004 Share Posted September 17, 2004 So what was wrong with it? Did I miss that post? Guy Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 17, 2004 Share Posted September 17, 2004 Quote So what was wrong with it? Did I miss that post? Guy ya.. no prob though. i had a vacuum leak right off the turbo and wastegate. it was making the boost do werid things and the afm do werid things. it pulls real nice now! mike Quote Link to comment Share on other sites More sharing options...
slownrusty Posted September 17, 2004 Share Posted September 17, 2004 Home made alcohol injection....VERY interested....have any details you can share Mike? Glad the car is up, running and hunting. Yasin Quote Link to comment Share on other sites More sharing options...
Guest Phailure Posted September 17, 2004 Share Posted September 17, 2004 glad you got everything worked out on ole blue. You should be proud you beat an evo. Those are pretty fast even without the AWD launch. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 17, 2004 Share Posted September 17, 2004 Phailure said: glad you got everything worked out on ole blue. You should be proud you beat an evo. Those are pretty fast even without the AWD launch. dude you have NO idea. i was screaming "HOLY CRAP, NO WAY, BOOST B!TCH BOOOOOST"!!! lol and Yasin ill get all info and post it as soon as i get all the details. dont wanna say something and then it be false or wrong. mike Quote Link to comment Share on other sites More sharing options...
john kosmatka Posted September 17, 2004 Share Posted September 17, 2004 And you said you were done with ole blue. You should have known Mike. Z's own you, you dont own them. lol Have fun Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 17, 2004 Share Posted September 17, 2004 Quote And you said you were done with ole blue. You should have known Mike. Z's own you' date=' you dont own them. lolHave fun[/quote'] lol sad but true. when i hit my 12 sec pass in this car ill be done with perfmance work. paint and body work is next and so is inteior. ill have it done before next year is up. mike Quote Link to comment Share on other sites More sharing options...
Guest Chris240turbo Posted September 17, 2004 Share Posted September 17, 2004 building your own alcohol injection sounds easy, but it's not really, call me up and we'll talk about it there mikey! 2 ways to go about it on your car, either before the turbo, which works only OK, the compressor atomizes the h2o pretty well, altough it might hurt turbo life? the other, prolly better set up uses a high PSI pump, and a nozzle that'll spray a fine mist, you'll need a pump that will put out maybe 20 psi, or at least for sure more than whatever boost you want to run, wouldn't work too well if you're running 10 psi boost, and your h2o pump is <10psi... I messed with an alcohol inj. set up years ago, triggered by an adjustable Hobbs switch, and could never make it work worth a damn, not to say it can't be done, but, how many high power turbo cars do you see running it? not many, at least not somewhere that you can still buy 93 octane pump gas, like here. 8) Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted September 17, 2004 Share Posted September 17, 2004 Quite a few Buick GN guys run Alky injection and a few run propane injection. If I remember right, a few have made there own injection systems. Check out http://www.turbobuicks.com and look at "Alcohol, Propane & Nitrous" for some information and ideas. !M! Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 18, 2004 Share Posted September 18, 2004 hm thanks Mat. and chris would a stock 280z fuel pump work? we can talk about this, i thought it would be fun and i could learn something for it too. mike Quote Link to comment Share on other sites More sharing options...
