Louiem Posted January 20, 2003 Share Posted January 20, 2003 I've been aquireing parts slowly and I'm almost ready to start my low budget chevy swap. I'm using the JTR book. So far I have gone by the book. It's going to be a mild 350 with a camaro 5 speed. What did most of you guys use for a drive shaft. I noticed the manual suggests using chevy u-joints and they have a flange available. Did anybody use theirs or did you have one made? How about the speedometer? Do we just use the cable avaible at JTR? Quote Link to comment Share on other sites More sharing options...
spdsk8r Posted January 21, 2003 Share Posted January 21, 2003 Louie, My first hybrid Z was a low budget conversion back in the late eighties. For a driveshaft I used the Camaro shaft and had it shortened by a local driveline specialist. I bought the yoke from JTR. My conversion had a Turbo 350 trans. for the speedo cable I used the stock Datsun cable housing and got a universal cable core from NAPA to fit a Chevy. The Datsun housing end is close enough to the Chevy in size, so I chased the thread with the appropriate tap to change it to fit the Chevy trans. That was my low budget way around those issues. I hope this helps. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted January 21, 2003 Share Posted January 21, 2003 Louie, you may find the part numbers for a flange from NAPA auto parts that will work, but use the search function in the "drivetrain" forum. I bought their flange because it came with the kit and was well made. Davy Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 21, 2003 Share Posted January 21, 2003 Neapco differential adapter # 2-2-899-1 for a Spicer GM 1310 ujoint to a R 200 Datsun differential Quote Link to comment Share on other sites More sharing options...
