Earley 60s 350
Guest Lee Smith
Guest Lee Smith
I have a early 60s pickup with a 350 4bbl.
The old Chilton ( car ) 295hp with 4bbl 10-1 comp
Could this be the same engine?
It has 175, + - 5, all cyl.
It looks good to me.
Any thoughts, oppinos please.
Lee Smith
1967 was the first year of the 350, and it was only in the Camaro. On the passenger side front of the cylinder deck, there should be a serial number and a letter code. If the letter code is 2 digits, it is a pre-1970 motor. If it is three letters, it is a 1970 or later motor. If dipstick is passengers side, it is a post 1977 motor. The letter code can be de-coded at www.nastyz28.com
Lee...The 350 SBC became avaialble in 1968.. 295 HP came usually in late 60's "Hot Camaros"... without comparing engine numbers it would be hard to decipher what HP it is and where the engine was originally .With the compression figures and 4BBl it all sounds very promising. Hot SBC engines wound up in a lot of old Chevy pick-ups.. Check this out web page or web page This will help you locate and identify SBC engines and all their parts.
