83' 280zxt stock car running 7-7.75 psi?
Thumper
Well I was out driving my car today with my newly installed autometer boost gauge and saw that i'm boosting 7psi at 2100-3500 then after that it will slowly raise to about 7.75 by about 6k. My car has an intake, 3" non-mandrel bent exhaust on it, and a fpr. I have read that the car is suppose to boost about 6 psi so what do you think is causing this. I did have to remove my Emergency Relief Valve because it would go off once in awhile. I'm thinking there is some carbon/gunk buildup in either the vacuum line or the wastegate. I will upping the boost to 10 psi when my boost controller comes so the boost creep should go away but i'm not sure. Thanks in advance
