auxilary Posted October 14, 2004 Share Posted October 14, 2004 holla folks. question for you all. My setup is as follows: -summit pro street 16 gallon sumped plastic fuel cell w/ anti slosh foam/gm senser -8an line to gravity fed walbro 255lph (43psi avg) inline external fuel pump, goes to: -8an line into a Y block to 2 -6an lines to 2 fuel rails, returning to: aeromotive fuel pressure regulator with 2 inlets, 1 outlet. Outlet (return) goes to fuel cell Can I plumb the return line into the second fitting on the sump, or does it need to be plumped from the top of the fuel cell so the fuel drips down into the cell? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted October 14, 2004 Share Posted October 14, 2004 I have my return line plumbed to the second outlet of my cell (no foam) and have had no issues. I have since installed a surge tank with second low pressure pump with the overflow return back to the bottom. If you do return to the top, you will have to drill a second hole in the cell for a vent/breather..... Tim Quote Link to comment Share on other sites More sharing options...
auxilary Posted October 14, 2004 Author Share Posted October 14, 2004 yeah, that's what I was originally planning on - another 6an fitting for the top, drill hole, plumb return there. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted October 14, 2004 Share Posted October 14, 2004 yeah, that's what I was originally planning on - another 6an fitting for the top, drill hole, plumb return there. I don't think it necessary, and will make plumbing a little less tidy.... Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted October 15, 2004 Share Posted October 15, 2004 This was yacked about before. Several guys said,"Oh no! you don't want to plumb your return into your sump! Turbulance, and bubbles, and lions and tigers and bears! Oh my!" Turbulance schmurbulance. I've had my return plumbed into the sump since I built it and no problems. (baffled sump) Quote Link to comment Share on other sites More sharing options...
z-ya Posted October 19, 2004 Share Posted October 19, 2004 I have the return going back into the sump on my custom spare tire well fuel cell, and it works fine. In fact I have had the cover off the cell with the egine running, and there are no bubbles coming into the sump from the return line. Have done 10 track sessions with the car so far, and have had no problems with starvation. Quote Link to comment Share on other sites More sharing options...
