FINAL DECISIONS IN OKINAWA JAPAN
Grumpy if you are out there can you please help out a distant friend! I have finally got my car out of paint and it can be seen under the paint album below. I plan on building the 450 HP setup on AFRs site. This is what I have so far...
350 .040 over
Scat 350 crank 3.48
5.7 Eagle rods
KB106 Flat Tops
Comp Cams XR282HR-10
Part Number 12-432-8
Grind Number CS XR282HR-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.51 0.52
Duration At 0.006 Tappet Lift 282 288
Valve Timing At 0.006
Open Close
Intake 35 67
Exhaust 78 30
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 230 236
Lobe Lift 0.34 0.347
Lobe Separation 110
I want to run a holley 750 DP
Hooker Block Huggers 2 1/2 Duals to X pipe and out etc.
I want to get the AFR intake that they recommend
I want to get the AFR 190 heads
I will have 3:54 rear gears 700R4 with 2800 stall
Do you think the AFR 195s will do a better job or should I stay with the 190s. Is there a better intake selection? I have already bought everything except the heads, intake, and carb.
Grumpy I need your advice before I buy the rest of these parts...which would be the best bet. Afr says 450HP from their specs??????
CorZette
Grumpy, I am a little confused. The book says the Compression Ratio should be around 9:5:1. When you say dynamic are you talking about the actual CR? Man 7:6:1 would be a dog. Do you think AFR makes a 62CC Head? Do you know any others that flow as well as AFR that may have a 64CC chamber? I am looking for around 9:5:1 - 10:1 ratio. Man its a good thing I asked you about....My pistons are the KB106 flattop type. My cam is a retrofit so cam rod clearances are not a problem. It all rotates freely..
CZ
I believe Grumpy is talking about dynamic compression which is lower than your cr #'s due to the cams duration being 230/236 at .50.
If you run a big cam you need to bump up the compression to deal with the bleed off.
I was using the kb hypers at 9.7 to 1 with 64cc heads but with a bigger cam I used thinner head gaskets to get closer to 10.5 to 1 compression.
I also run 93 octane as Texas still offers it.
I was unhappy with my cams 238/244 duration at .50 so went to a hydraulic roller with 224/230 duration and a dual plain intake and I love it. Still plenty of lump to it!
I am running a Holley 750 dp'er and like it with exception to fuel economy or lack of but what the heck I like it better than my 750 Edelbrock.
Good luck with what ever you decide to do just keep us noisy people up to date.
Mike
This is what I get with the calculator:
Cylinder Head Volume (cc) 68
Piston Head Volume (cc) 7
Gasket Thickness (in.) .038
Gasket Bore (in.) 4.060
Cylinder Bore Diameter (in.) 4.040
Deck Clearance (in.) 0.00
Stroke (in.) 3.48
COMPRESSION RATIO 09.804
If I use the Gasket bore of 4.060 vice 4.125 I get a little higher CR as well. How do these numbers look Grumpy? I think I will stay with the AFR 190s. Do you think this build would put out anything close to 450HP? Seems a little high to me...
CZ
Roger that, I understand. I used the calculator and I get around 7:7:1 ratio. You said I was slightly off....what would be a good target to shoot for? Say 8:1:1 or so? If I go with what I have now would I be giving up alot of power?
Sorry so many questions but I want to do it right the first time. You are the motor GOD you know! I was thinking about maybe 64 cc heads to be in between but AFR doesnt make those I dont think....
Terry
theres little if any differance between the AFR 190cc and AFR 195cc heads, other than the intake port gasket surface port size, Id get the 195cc size and have them mill about 10-15 thousands off to lower the combustion chamber size slightly, you have almost everything correct,but even with the 68cc head your dynamic compression will be slightly low with that cam, at about 7.6:1 so use the thinnest head gasket that gets you about a .038-.041 quench and very carefully check pistion to valve clearances and rod to cam clearances and if you order the heads with a 62-62 cc combustion chamber the engine will make more power but limit you to high test gas at all times, IF you have access to 93 octane gas,if you don,t have 93 octane ALL THE TIME, leave the heads at 68cc if you don,t have a steady supply of good gas! BTW that cam is very similar to the one Im running in my 383
http://dab7.cranecams.com/SpecCard/DisplayCatalogCard.asp?PN=119661&B1=Display+Card
which I picked for its greater lift and smoother idle mostly due to the wider 112 LSA that makes it a better NITROUS cam
even though your cars light I think youll be slightly better off useing a EDELBROCK AIRGAP RPM INTAKE for massive mid-range torque and a vacuum secondary 750-780cfb carb, DP carbs work well when used at the track where your foots on the floor most of the time but if you intend to drive on the street get the airgap/RPM and vacuum secondary carb, youll be much happier!!!
8.2 :1 is what Id be trying for with a set of aluminum heads, now the differance in hp is about 4% for every step up in compression
example
at 9:1 if the engine makes 400hp
at 10:1 its likely with no other changes to make about 416hp
now Ill grant you thats not what looks like a huge increase but that 16hp is over the whole rpm range not just the peak. and since your buying pistons you might as well get the best cpr pistons you can because theres very little cost differance. keep in mind milling the heads slightly to lower the combustion chamber voluum and useing a thinner head gasket are also options.in your case just changeing to a slightly thinner head gasket and a minimal head mill of about .015 thousands will get you there. but talk to AFR like I said before the differance is minor and might not really be worth worring about if a few hp and a few ft lbs of tq are not worth the costs involved. what Im trying to get accross is that
its the little things that add up!its the minor changes made durring the planing and assembly phase that make the differances!
heres a few examples
your dynamic compression ratio is what matters and thats to a large part determined by the relationship between the static compression ratio and your cam timeing
at 9:1 static cpr if the engine makes 400hp
at 10:1 static cpr its likely with no other changes to make about 416hp
now Ill grant you thats not what looks like a huge increase but that 16hp is over almost the whole rpm range not just the peak. and since your buying pistons you might as well get the best cpr pistons you can because theres very little cost differance. keep in mind milling the heads slightly to lower the combustion chamber voluum and useing a thinner head gasket are also options. just changeing to a slightly thinner head gasket and a minimal head mill of about .015 thousands will sometimes get you there. getting the quench into the .035-.042 area of clearance, useing oil retaining piston skirt coatings,ETC. but talk to your head and cam manufacturers like I said before the differance are minor and might not really be worth worring about if a few hp and a few ft lbs of tq are not worth the costs involved to you but the differances add up! what Im trying to get accross is that the differance between a very good engine combo and a great engine combo is the slight differances made,
its the 50hp you get from useing great flowing heads verus the stock heads
its the 40hp you get with a stroker crank assembly versus the stock displacement
its the 30 extra hp you get by correctly picking a perfect cam verus useing the hot cam your buddy suggested without checking if it truely matches YOUR COMBO
its the 3-7 hp get from ballancing the engine assembly,
the 5-7hp youll at least at high rpm get by running longer connecting rods,its
the 3hp from perfectly fitting pistons versus too much clearance and
the 7 hp from a cam thats advanced or retarded to get the most out of it, and
the 15hp you get by getting your cpr exactly where you want it and
the 4hp you get with synthetic versus mineral oil, and the 3hp you get by gapping your rings correctly, its
the 5hp you get by port matching and
the 20hp you get by smoothing and blending the bowl and chamber areas, its
the 12 hp you get by useing long tube headers versus short tubes and
the 15 hp you get by useing a merge collector with a full length free flow exhaust versus a standard collector and stock exhaust
its the 3hp that you get from running the correct fuel pressure.
the 5hp you get with a windage tray
the 8hp you get from a good free flow air filter
ETC.
as examples, that combined make the differance, not some special super part you installed, ITS THE SMALL DIFFERANCES THAT ADD UP!
Man Grumpy thanks for taking the time to post that...sounds like the secret ingredients to a winning combo. My next engine will be a 383 or 406 for sure. Ill see if they can mill the heads .015 before shipping and use a .038 with 4.150 or so bore gasket....
CZ
