grumpyvette Posted February 5, 2003 Share Posted February 5, 2003 heres some good info you need to read http://www.totalseal.com/howdoo.html http://www.aera.org/members/enginetech/edge1296/page3.htm http://www.muller.net/mullermachine/docs/ring_lap.html http://www.hastingsmfg.com/service_tips.htm http://www.sswesco.com/ss/sssugges.htm http://www.pontiac.tm/goat/rings.htm http://www.babcox.com/editorial/us/us20114.htm http://www.lunaticams.com/PistonRings/Ring03.html http://www.holley.com/HiOctn/TechServ/TechInfo/IECPTech6.html http://www.propowerparts.com/products/rings.htm http://www.kb-silvolite.com/speclear.htm#CHART http://www.hastingsinc.com/Service%20Tips/ring_gaps.htm http://www.precisionmeasure.com/block16.htm http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=85487&prmenbr=361 http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3301&prmenbr=361 or if your careful a DREMEL tool can be used very effectively useing the edge of a cut-off disk just some info Ive broken a few rings over the years useing this type compressor this type works much better but this type is the easyist to use fom my expeariance just some extra info, I normally use piston skirt coatings that retain the oil film better and heavily coat parts with MOLY SPRAY during assembly and polish the combustion chamber and piston crown surfaces and smooth and round off the valve edges and pistons valve clearance knotchs. I personally have seen no big gains from piston dome and combustion chamber coatings the few times Ive tried them, and don,t personally think they are worth the extra expense on engines most of us build for street strip use. http://www.msmoly.com/ http://www.sandstromproducts.com/Tigs/e720.pdf http://www.etoolcart.com/product.asp?3=401 Quote Link to comment Share on other sites More sharing options...
Rob Posted February 6, 2003 Share Posted February 6, 2003 Thanks as always for the information Grumpy. Reading your posts is an education. I'm curious what your opinion is on gapless rings. They seem like the best thing since sliced bread but are there any problems or compromises with them? Seems like if they really have 1/10th the leakdown of conventional rings (2% vs 20% according to Total Seal) then everyone would use them including oems. Sorry if the answer is in the info, I read some but not all of it. Quote Link to comment Share on other sites More sharing options...
Mudge Posted February 6, 2003 Share Posted February 6, 2003 My understanding is that past break in, they leak down just like normal rings. But I await an experienced answer with you Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted February 6, 2003 Author Share Posted February 6, 2003 Im useing TOTAL SEAL GAPLESS RINGS in my vettes 383 and have used them many times in the past, personally I doubt that they are really worth the extra price which can be 3 times as much but yes they do give you about an extra 7-10 hp (not what TOTAL SEAL CLAIMS) but still better than most conventional rings. its your choice, like I said yes they work, but the hp gain per dollar return at least from what Ive seen is minimal Quote Link to comment Share on other sites More sharing options...
Mudge Posted February 6, 2003 Share Posted February 6, 2003 It always gets expensive going for that last little bit. Quote Link to comment Share on other sites More sharing options...
